Revit Tagging Rebar
Revit Tagging Rebar
HumbleGuy
Message 1 of 8
Revit Tagging Rebar
HumbleGuy
Greetings!
I'm trying to annotate the reinforcements. Shown on this example there are 4 rebars in the column but Revit shows 1 as the quantity. How can i show there 4? In the second photo you can see what i want but i did it not with tag tool, but with text tool.
Thanks for help in advance and have a nice day!
Replies (7)
Message 2 of 8
Are you saying that the rebar is in a REBAR SET; Fixed Number=4?
Message 3 of 8
HumbleGuy
I mean, there are 4 pieces rebars in the column. But the tag shows "1".
Message 4 of 8
Are they part of a REBAR SET or did you place individually (one at a time)?
Message 5 of 8
HumbleGuy
I've placed invidually
Message 6 of 8
Well then, there you have it.  Revit doesn't know that.  If you want Revit to tag as a 'UNIT", then put the 4 into a REBAR SET.  Otherwise, tag individually.
Message 7 of 8
HumbleGuy
If i put 4, then i have 4 rebars in one single direction. But i need 1 rebar for each corner at the column.
