- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have been unable to find a solution for extending the Stringer past the Tread in Revit.
In this old 2011 solution, one could simply lengthen the sketched Tread line:
https://forums.autodesk.com/t5/revit-architecture-forum/stair-stringer-extension/m-p/5503381/highlig...
However, after reading Adam Hamilton's later comment, the advent of the component Staircase in versions 2013+ has eliminated this as a current solution.
In the end, I would like to extend the Stringer past the Tread so that I may transition it into the Baseboard like so:
I have been researching this for over an hour and have come up short. Hopefully someone here will have a solution, so many thanks in advance.
P.S. - I have attached the staircase in question as a separate RVT file with Section.
