Revit still sees a downloaded cloud model as a cloud model even after downloading the file
onyemaudezed
Message 1 of 13
onyemaudezed
I once saved a Revit file to the cloud and later downloaded it because I needed to convert it to a Revit template. Now, Revit still sees the file as a cloud model because I cannot save it as a cloud model anymore and the save as template option is still greyed out even though the file is now locally saved on my PC.
On another note, when I open the file, all the browsers will disappear - project, properties, and systems browsers... I always have to manually restore them all.
Please, how do I fix this?
Version: Revit 2023.
Replies (12)
Message 2 of 13
You need to disable worksharing (open the file detached and choose discard workset) in order to save as a project template.
Message 3 of 13
onyemaudezed
Hi, @ToanDN; thanks for your response. But the file is not workshare-enabled.
Message 4 of 13
Can you open Worksets dialog and show it here?
Message 5 of 13
onyemaudezed
Hi, @ToanDN; I just noticed that the file has become workshare-enabled, perhaps after making it cloud-hosted. The tricky part is that the option to detach from central is greyed out when I try to access the file from the open menu in Revit.
Message 6 of 13
Is it the file you downloaded to the local drive?  Share it here.
Message 7 of 13
onyemaudezed
Okay
Message 8 of 13
It doesn't work here either.  How did you download this file?  You should have opened it from the cloud to create a local file, close the local, then re-open the local and detach from central will be available.
Message 9 of 13
onyemaudezed
Hi, @ToanDN.
Honestly, I almost lost access to the cloud model at some point, as Revit was giving me some error messages. I  suppose the file did not properly publish when I shut down my PC then. So, I had to trace the latest local cache file. I  guess there are some internal corruptions in the file. I'm surprised to see the worksets becuase I never enabled worksharing in the file.
Message 10 of 13
RobDraw
Like you said. You maybe you did enable worksharing when you made it a cloud model. Do you remember how you made it a cloud model? Do you still have access to the cloud model to check to see if worksets are enabled?
Rob
Message 11 of 13
onyemaudezed
Hi, @RobDraw .
I made  it a cloud model by saving it to the cloud from Revit  - without enabling worksharing. Does that automatically create worksets?
I will check the cloud model to see if it has worksets. Although I have made several changes to the local file...
Message 12 of 13
RobDraw
Hi, @RobDraw .
Sorry but that's hard to answer because your wording isn't very precise. I know it is possible to have a non-workshared model on the cloud but it's been a while since I worked with them and workflows may have changed since.
You haven't stated where this project actually resides. Is it one of Autodesk's cloud platforms?
Did you "save as a cloud model" or "save as" to a cloud drive or "collaborate in the cloud"?
Rob
Message 13 of 13
onyemaudezed
Hi, @RobDraw .
I used the 'Save as' command in Revit which saves it to Autodesk Construction Cloud - Docs module.
