revit stairs
revit stairs
batshevaglatt
Observer Observer
Message 1 of 9
revit stairs
batshevaglatt
Observer
Observer
hi
i would like to know if it's possible to create stairs in Revit containing two materials for the rises and treads?
i attached a pictures to show you what i mean...
hope someone can help
thank you!
Replies (8)
Message 2 of 9
mpeperkamp
Hi @batshevaglatt,
Welcome to the Autodesk forum.
Yes, you can do that.
In the picture you can see how you can do that.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Message 3 of 9
batshevaglatt
Observer
Observer
hi
@mpeperkamp thank you for your reply.
I don't think this is the answer to my question.
If you look at the picture I attached in my previous post, you can see that both the risers and the treads are each composed out of two materials.
In this case it's a steel construction covered by wood.
is it possible to copy that in revit?
hope you understand what I mean
Message 4 of 9
@batshevaglatt: I think @mpeperkamp did answer your question, but if you want another method: try using the Paint Tool to apply a veneer like is shown in your image.
Message 5 of 9
...btw, I don't "see" it the way you do. I see a single steel stringer (perhaps an inch thick) with composite wood treads and risers attached to it. That's how I would build it.
Message 6 of 9
Message 7 of 9
batshevaglatt
Observer
Observer
@barthbradley
this is exactly what I need. Can you explain what you did?
thank you very much
Message 8 of 9
It’s a “Run Type” (listed under “Construction” in the stair’s Type Properties)
Run Type Properties:
System Family = Monolithic Family
Underside Surface = Stepped
Structural Depth = 0’ - 1”
Tread & Riser Thicknesses  = 0’ – 2”
You can define the Monolithic, Tread and Riser materials in this dialog box as well (under “Materials and Finishes”)
I used the Paint tool to apply the “veneer” material o/ Tread & Riser faces.
Message 9 of 9
batshevaglatt
Observer
Observer
Thank you very much! It helped me a lot!
