Revit Site Designer 2019
Currently I installed the revit 2019 and in the search knew that site designer did installation of the site designer does not appear on the tape after installed in revit 2019.
Luiscko
If you update your Revit from 2019 to 2019.1 maybe  delete some elements in your add-in i recomend you that you uninstall the site designer and instal again is in the manage autodesk where you can download again, if you have site designer in later version only are aplicable for this version and in Revit 2019 you will need to install the Site Designer 2019.
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
I uninstalled the revit 2019 and returned the revit 2018, all right even without understanding why I appear version for thirty days.
Luiscko
i recomend you that you check your email because Autodesk send you the number of licence there or if you sign up in your Revit maybe could be recognize your license obviously you need to sign in with the user that you buy your license.
Luis Rodríguez
Your Name
I installed revit 2019 student downloaded from website 30 12 2018 after having formatted my notebook and the disgner for revit website add-in downloaded from the site but does not appear to me when I open a file in revit. the install completes but I do not see it, I reinstalled and did repair and nothing.
