Revit Sheets plotting with image clipped into walls/furniture
cheekyinez
cheekyinez
Community Visitor
Community Visitor
I am having an issue with my batch plot (have tried both print and export to PDF) as I try to PDF my sheet set where in certain plans, portions of my what appears to be the site aerial image are being clipped into my walls/furniture. I have attached snippets of an example of the clipping issue, the site plan that I think is the culprit and the print/export settings I have attempted. I'm using Revit 2026. Has anyone had this happen to them/know what could be the issue?
nozci
You inserted aerial image into your drawing and hid temporarily using this button
and before printing Revit asks you if you wanted to print temporarily hid items or leave it as it is and you are selecting yes. Either click No or hide the aerial image using right click and hide then it won't ask you before printing.
cheekyinez
Community Visitor
Community Visitor
Thank you!
nozci
Did it solve your problem?
mari.shimode
Hi @cheekyinez, since it seems you found @nozci's reply useful, I have marked it as an accepted solution so others who have the same question can refer to it.
If you have any other questions related to what you originally asked, please create a new topic with a link to this post included so the community can follow the conversation easily. Thank you.
Mari Shimode
