Revit sheets export to one cad file
kjones48L7S
kjones48L7S
Revit sheets to one DWG
Is there a way to export Revit sheets/views to one cad file?
Is there a way when using MLAce to save the Autocad file as one file that I can send to Engineers?
-Revit sheet exports w/ views pulled up with MLAce add on in CAD
emmanoelneri
Try to use the ProSheets plugin from Diroots.
https://apps.autodesk.com/RVT/pt/Detail/Index?id=7448218013676619378&appLang=en&os=Win64
There are a lot of settings for printing, including DWG
