Revit sheet to dwg
Revit sheet to dwg
Message 1 of 8
Revit sheet to dwg
I am trying to export a sheet with perspectives, it will not export with or without xrefs, the sheets without perspectives export fine.
Cheers
Replies (7)
Message 2 of 8
mp_thompson
You should be able to do it.
Can you send the RVT file and I'll have a look?
www.thompsonarchitecture.co.uk
Message 3 of 8
I tested with a Shaded perspective, a Realistic + shadow perspective, and a rendering view (saved as image to project from one of the perspective view).  All came in AutoCAD drawing just fine.  Shade view became 2d lines with surface hatch.  Realistic view became 2d lines, no texture, no shadow.  Image became image.
Message 4 of 8
Hi Matthew,
Here is a link from a360  http://a360.co/2iQZf9S . Tried it again and still no success. Its probably something really simple.
Cheers
Malcolm
Message 5 of 8
mp_thompson
Seems to have worked ok for me, I've uploaded it to A360 for you
Message 6 of 8
mp_thompson
It's worked with and without the XREF box checked.
Your perspectives are tiny though (see attached image, they're in the circle)
Message 7 of 8
mp_thompson
Message 8 of 8
Hi Matthew,
I see what you mean, they are there I assumed that the dwg hadn't worked
cause I only saw the site plan, the views are all in MS so I will adjust and
ad viewports to suit.
Malcolm
