I'm working on a project where I will use a sheet template from the costumer to produce drawings.
The problem is that the text boxes where the project information goes is only a questionmark, and I can't write anything in the box.
Does it have something to do with the shared parameters?
Does it have to be done manually in for example AutoCAD?
When I double click the template and go to edit mode, the correct information is present at their text boxes.
