Revit – Shared parameters not showing up in schedules
cntentertainment337
New Member New Member
cntentertainment337
New Member
New Member
Hi all,
I’m running into an issue with Revit (2024) that’s driving me a little crazy. I created a few shared parameters for some custom furniture families (things like material code and vendor ID). The parameters are working fine in the family editor, but when I load the families into the project and try to build a schedule, the fields don’t appear as options.
Here’s what I’ve tried so far:
  • Double-checked that the shared parameter file is the same one linked in the project.
  • Verified that the parameters are set to “Instance” and “Text” as intended.
  • Reloaded the families multiple times.
  • Even created a new project with a fresh template to test.
Still no luck. Am I missing a step to make these shared parameters accessible in schedules, or is there a known quirk with this version of Revit?
Would really appreciate any guidance — I feel like I’m one checkbox away from solving this.
Thanks!
RDAOU
@cntentertainment337
post the family you added those parameters to
