Revit Shared Parameter Service
Patrick_Tak
Message 1 of 1
Patrick_Tak
We started experimenting with the Revit Share Parameter Service. We enabled the services in our ACC environment. Created a couple parameters as test and then opened the service from Revit.
We see the default screen like the services isn't setup.
If we then switch to the build-in IFC parameters... voila there are our entered parameter!
But they only stay there while the IFC parameters are loading. Once the request is done loading. The IFC parameters appear, but our parameters disappear.
What do we need to change so that our list op parameters appear in Revit. Is there a setting that we missed? It is the same in Revit 2023 and Revit 2024.
Thanks for the help. 
Replies (0)
