- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi sgoodmansen,
Thanks for the confirmation that my work place is using a File-Based topology which is also what I had thought with a 90% confidence. After my company had failed to meet a project deadline through worksharing collaboration of using Revit 2015. I start to wonder if the established Revit Server workflow is really effective for wide geograhic distances. After I read this article attached below, I generally understood the benefits of using the Revit Server accompanied by Riverbed accelerators for two fundamentally different workflow topologies : Server-based and File-based. The tests performed in the article clearly indicates that Server-based topology delivers the greatest overall performance which minimizes the WAN traffic with the least amount of time required to perform Sync w/ Central, Reload Latest, Element Borrowing and Element Relinquish than File-based topology, despite the fact that network compression with Riverbed accelerator is more effective for File-based workflow.
I just like to know what are the drawbacks of using a Server-based workflow which is not the current workflow topology being used by my company. If considered, would this be more appropriate than File-based workflow for documentation worksharing across three geographically long distance locations ?
Also, I just want to get some clarification about the "Local Revit Server". I know for sure that all the central files are stored on the web-based file server (see attached screenshot with the server circled in red). All the locally saved Revit files are backed up in the Documents folder under the C: Drive, and the cache contents are all defaulted to C:\Users\username\AppData\Local\Temp. But there is no Central Revit Server in this case, because it is a file-based workflow which means that no Local Revit Server should be used or connected to the Riverbed accelerator across the WAN, correct ? The only time when Local Revit Server/Servers can be used is in the scenario of a Server-based workflow, such that the Local Revit Server (a physical piece of hardware/ machine) must run in parallel with an accelerator per geographic location and using only the Local Revit Server instead of the accelerator to cache data within local area network (LAN). There would also be a Central Revit Server( a physical piece of hardware/machine) residing at one of the geographic locations, but the central models/files are stored across the WAN, not on the central server, correct ? Sorry for asking many the questions at once, I hope my questions are clear and easy to understand. Thank you.
