Revit Section Filled Region Hatching PDF conversion problem
sdi2E3SP
sdi2E3SP
Hi all,
We have been working on a central file with several section views with filled regions with hatchings.
A week ago, we exported one section to PDF without problems, but somehow we are running into problems now.
First of all, we can't get the hatching to show (only white regions), when using "Vector" processing (File: New_1_20_vector). When switching to "Raster" processing, the hatchings are converted to completely filled areas and all lines seem to be very thick as well (File: New_1_20).
If we change the scale of the section from 1:20 to 1:50, the hatchings appear normal again (File: New_1_50), but unfortunately we need the 1:20 scale.
Can anyone help to solve this problem?
sdi2E3SP
We found the solution for this. Apparently someone changed the Line Thickness of the 1:20 elements.
