Revit schema folder 2021
charlescarter22
charlescarter22
revit reinstall and repair not working. same message. is there  a fix?
nmarcelis
Could you provide some more details on the problems you're experiencing?
For what particular reason did you reinstall Revit?
-Did the application freezze, become irresponsible, critical error?
Do you have third-party apps installed?
What Windows version are you using and is it a network or named user license?
I am happy to help you if you can provide more info.
Revit Certified Professional Architecture, Structure and MEP.
nmarcelis
After doing a quick search on ''missing schema'' I found this potential solution for your error.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Basically open the Autodesk desktop app and click My updates.
Or
If this doesn't work manually install RevitUnitSchemas.msi , it is located on C:\Autodesk\WI\Autodesk Revit 2021\x64\RS
Don't forget to Reboot
If this helped you don't forget to accept as a solution.
