Revit Schedule Customization
dcarl.ips
dcarl.ips
I am wondering if there is a way to highlight every other row with a grey hatch to make reading the schedule easier. I kind of cheated by drawing a filled region behind a schedule on the sheet (see attached), but, it doesn't update when the schedule is changed, so I have to manually change the filled region every time there is a design change.
Is there an easier way to do this in customizing a schedule? If not, is there a way to pass a note on to the developer? I feel this would be an extremely useful feature.
ryan.duell
It is currently not possible to do this in the schedule data section (only the title section you can add fill manually).  This is a documented request with the team that owns the schedule feature – I can pass along your additional feedback as well.
Thank you,
Ryan Duell
