- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
All,
is it possible to detail an extrusion that is on 4 different ref planes? - See attached Zip file.
The rectangular lines sketched within the pdf show an indicative panel layout. in order to achieve my goal, i need to get this drawing from model lines to extrusions. due to the complex geometry and various planes i cannot work out how to model my extrusion into the rfa.
I have a curved soffit design that starts at a vertical plane (90degrees) and slopes around a corner before becoming a horizontal plane (90degrees). The facade panels are twisted round the corner and i need to be able to present this curvature/twisting to the customer with appropriate panel sizes and structure.
(Unfortunately i am unable to post the .rfa file here due to client confidentiality/data protection.)
i am not really after a solution on how to detail the soffit, just a bit of insight on how detailing an extrusion on different planes is achieved. if this cant be done, does anyone have any bright ideas on how i can achieve this?
i have thought about using a sweep, but again an cant seem to get this to work.
any suggestions/solutions will be greatly appreciated.
