revit rendering issues
vikas2ABD2
Observer Observer
vikas2ABD2
Observer
Observer
 Hi
I am trying to render some images on revit but i get stuck, the desktop is a decent config but when rendering its taking upto 30 minutes on it. Is it lacking the CPU power or do you think if i upgrade the graphics card, it will be ok.revit.jpg
cbcarch
The CPU spec looks good-- 3.78 Ghz is pretty fast.
Graphics card ( GPU) will not help in rendering with Revit, as it is only using the CPU.
Try using a Section Box to crop unneeded elements fro the view.
Turn off unneeded Model categories, Linked Revit and Cad, etc.
Do you have a lot of lights in the scene? If so, turn off the ones that are not in the view.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
ennujozlagam
What is your graphics card model? Try to install latest updates of your graphics card driver. You check below requirements before planning to buy. Thanks
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/S...
Viveka_CD
Hi @vikas2ABD2
Are you rendering locally or in the cloud? Do you have multiple textures, if so use a relevant size/format.
Can you confirm if you have the latest updates for your Revit version?
See best practices on rendering and as suggested by @ennujozlagam update your graphics card driver from the manufacturer's website.
Check compatibility for Revit version and your graphics card. See troubleshooting guide
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
aRcHiTeCt.JM
... for REVIT rendering...
... the more cores the better
.... faster .... reliable
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
