Spot Elevations
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
zemeraloni
2102 Aufrufe, 5 Antworten
Spot Elevations
Hi all,
I want to create a spot elevation in plan view that read and show both the top surface of the floor and top surface of it core layer.
All of the spot elevation types i saw didn't have this option. It's seems like something that should be easy to make because the parameters are there so it's only about how to read and show them up. Can it be done?
Tnx in advance!
Zemer
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: zemeraloni
A Floor Tag can do that. No? Check the parameter fields available to choose from. I think there is Elevation at Top/Bottom of Core.
...Yep.
Nachricht 3 von 6
zemeraloni
als Antwort auf: barthbradley
Hi Bradley,
First tnx for your response!
I've tried what you suggested but the tag somehow do not show the top core layer although the lable is there.
The only valu i was manage to see is the floor top surface. Do you have any idea why?
Tnx
Zemer
Nachricht 4 von 6
Unfortunately, this works only on structural floors, not architectural ones.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 5 von 6
zemeraloni
als Antwort auf: Anonymous
TNX!
The solution was so simple! BTW i stil don't get why (or how) spot elevation and not tags that looks like spot elevation do this simple thing..
Zemer
Nachricht 6 von 6
ubaldurban
Unfortunately, it does not work on sloping floors. I have a floor above the underground garage that is sloping due to drainage, and it contains structure (core) and thermal insulation above.
So I am unable to use spot elevation and tag does not work neither.
