Revit -Reinforcement for Circular Beam – Hooks Misoriented
mous7aphaMSE8P
mous7aphaMSE8P
Hello everyone,
I am modeling reinforcement for a circular beam in Revit.
The stirrups correctly follow the curve of the beam.
The problem is that the hooks are misoriented: they point outward, whereas I want them to point inward.
I have tried:
  • Flip / Reverse Rebar Set
  • Changing the hook angle (135° → displayed as -135°)
  • Recreating the rebar using path
But the result is still not correct.
Useful Information:
  • Revit Version: Revit 2026
  • Beam Type: Circular, reinforced concrete
  • Method Used: Rebar by Path with distribution
jacquesrigal3467
Hello @mous7aphaMSE8P ,
Do you want this result ?
Sorry the paste of images does'nt work.
See the file below.
Just for your information, you are on the french forum.
Regards
Jacques Rigal
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
