Revit Railing Baulster Start\End Offset
jaron.kasiban
jaron.kasiban
I have created a railing in Revit that combines baluster and profile families. I have stone pillars that are supposed to be used as baluster posts but are needed to be placed at specific points at varying distances so I've turned it into a generic family in order to manually place them in my project.
The issue that I am having is that the I like the placement of my balusters but I want my railings to extend into my pillars as shown in the image. Is there a way that I can extend my railing profiles or have a start/end offset to my balusters. I need the tall balusters to start and end with every railing which is why I have my pattern justify at 'spread to fit'.
jaron.kasiban
I forgot to mention that the pillars are at varying distances AND angles
Mike.FORM
The only parts of railings that allow the extensions you are looking for are the top rail and the handrails 1 and 2. There is nothing in the Rail Structure (Non-Continuous).
Here I have use the top rail element and handrail 1 with extensions of 300mm.
This does mean that each section between your posts is its own railing and the post family will be placed separately.
