Revit: Put Door deeper into Wall thickness
wisedrawing
Message 1 of 12
wisedrawing
I know this should be an easy one but I cant seem to find an easy answer
the wall is a generic wall with no multiple construction
Replies (11)
Message 2 of 12
Create an instance offset parameter from the door to the host wall. If you open an OOTB commercial or residential door family you will see the parameter is built-in.
Message 3 of 12
wisedrawing
Sorry  I will need to know where that is supposed to be?
I looked for it,
this is ootb Revit door
Message 4 of 12
Try a commercial door.
Message 5 of 12
constantin.stroescu
You have to create a new parameter , preferable an Instance parameter that controls the position of the door within the host wall..
I've attached two of my door families that have this parameter.
One of it is a change made to a door gathered from internet, the other one more simplified created by scratch..
Constantin Stroescu
Message 6 of 12
Why don't you just create a host wall for the Door? Basically, model it the way it will be constructed in the real world.
Message 7 of 12
Another way if you don't want to mess with the door family parameters:
- create a curtain wall type, set it to auto embed
- place a curtain wall of that type in the wall and it will cut the wall, set the curtain wall to match the door dimensions, change the curtain panel to a basic wall type
- you can move the curtain wall freely within the thickness of the wall
- host the door on the panel wall
Message 8 of 12
wisedrawing
Thanks all, sorry was away from the forum for a bit
replies appreciated
cheers
Message 9 of 12
wisedrawing
Constantin I went through the parameter inset and I had to amend the sketch as the door itself and swing were too long after I amended the inset depth but it seemed to affect all the doors - I am not sure i did this properly is there a point by point instruction somewhere?
Message 10 of 12
wisedrawing
sorry also my door does not have this parameter in the family editor
Message 11 of 12
constantin.stroescu
  • the inset parameter has to be Instance in order to can be different from one door to another
  • the inset parameter it's not an OOTB one . It has to be created by you - as I shown in the attached screencast
in the following screencast you can see how to create from scratch a simple door with an instance Inset parameter
https://www.youtube.com/watch?v=bx6USAOuubM
Constantin Stroescu
Message 12 of 12
wisedrawing
thanks for putting that up
I can see I will need to set aside some time and get that practiced up
cheers
Daz
