Revit Printing to PDF Quality Issue.
ash.alam5CVDD
Observer Observer
ash.alam5CVDD
Observer
Observer
Hi the issue is, when in the model space & in sheet the colour line weight is very good just like what i want but when i print to pdf the quality drops line-weight doesn't match. I have attached previous example.
rxi.gg
Check the view with the "Thin Lines tool" enabled to see real thickness of the lines
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
