Revit Print To PDF crashes on vector
1 REPLY 1
Amniisia
184 Views, 1 Reply
Hi
When printing to PDF with vector the program crashes, it doesn't crash on rasterize but I can't have that as a solution since I need to use vector. So far have found nothing that has worked for me.
Any ideas?
1 REPLY 1
alan_eu
in reply to: Amniisia
How much external (skp, dwg, 3dsmmax, etc) do you have on your project? Sometimes it overloads your CPU and GPU and returns you an error...
Didi you try to use the native 2022 export tool?
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
