Revit Plan Region settings being applied to areas of the view outside of plan region
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good Morning
In one of our projects, when a plan region is modified, the view range modification is happening outside of the plan region as well.
See the snip below.
In the upper-left corner, there are 3 bleachers. There are no walls under the bleachers. Thus we need to show the bleachers in that corner from the top. There are bleachers at the bottom of the screen. Those need to be shown as cut because there are walls and rooms underneath them.
When you apply the plan region it cuts both the bleachers in the upper left and the bleachers in the bottom.
See snip below. This happens regardless of where the plan region is placed in the view.
What would cause the settings for a plan region to apply to the whole view instead of just the area of the region created?
Thank you for your time.
