Revit parametric arrays with changing height of each element
HiTεsH
Message 1 of 9
HiTεsH
Hey there,
I have an issue with parametric arrays in revit I have created array of a nested family which is changing its no. of elements by a length, but now i want to do some tricky thing here that i have array in a sloped condition where i want elements to fix the bottom but my top is changing, but as we know arrayed elements are in group so how can i make the top constrain to fix at certain height and bottom will be according to slope.
Attaching one image for  better understanding.image_2021_05_03T05_11_39_479Z.png
Replies (8)
Message 2 of 9
HiTεsH
@ToanDN @barthbradley can you please help me out on this
Message 3 of 9
You can't. An Array is a copy. One for all and all for one.  You might be able to get there by editing the profile of a Curtain Wall though. FWIW.
...or a Repeater.
Repeat Adaptive Components | Revit Products 2016 | Autodesk Knowledge Network
Adaptive Family Repeated along a Divided Line:
Message 4 of 9
HiTεsH
@barthbradley Thanks for the reply, but in my case curtain panel will not work because i have one family made of multiple nested ones and that merged family i am trying to manipulate in a main family so i think it is not possible to do like that am i correct?
Message 5 of 9
RDAOU
@HiTεsH
You can nest that family into a baluster ... then use Railing to create that slanted bottom and flat top alignment.
Balusters' Base should be  attached to Host and the sketch section at the Ramp/Slope should be set to Flat. Once done, unpin top rail and delete it to end up only with the balusters.
Message 6 of 9
@HiTεsH : Post your family here. Let's see what can be done with it.
Message 7 of 9
HiTεsH
But in your case you are adding that baluster family to project and use a railing command. but in my case i am nesting that family into another family. so i think in family environment i cant do that
Message 8 of 9
HiTεsH
Yes Sure but i don't have the final one, but i have one parent family with slope and the family i want to constraint its already nested so you can try your hands on.
Message 9 of 9
RDAOU
@HiTεsH
All I can tell from what you have posted is that family is a set of Vertical supports that look and function like balusters. Even that slopped element hosting the supports can be part of the Baluster/railing...
But again...who knows maybe you have further plans and more components to model in that family beside those vertical posts.
