Revit or Revit LT
1 REPLY 1
253 Views, 1 Reply
Revit or Revit LT
I am looking at setting up our small construction company with Revit (it facilitates our Layout with a Topcon LN100)
But it would also be convenient to use the model for material take-offs which I understand it is capable of. Is this available in both the full version and the LT version, or just one or the other?
Scott.
1 REPLY 1
http://www.autodesk.com/products/revit-family/compare/compare-revit-products
A quick glance tells me scheduling and material take-off are comparable between Revit LT and Revit.
Worth noting that Collaboration, Worksharing, Parts and Assemblies, and datalink do not present in Revit LT.  If any of these are important to your company, then I suggest you go with full blown Revit.
