Revit options "No element in a secondary Option can be referenced by an element
NathalieKD
NathalieKD
Help! I get this message "No element in a secondary Option can be referenced by an element outside that Option" when trying to make an option primary. Is there a work around it, I dont know which step went wrong, and now I'm stuck with another option as primary!
Thanks in advance
Can you expand the warning to see the error?  Check for the element ID and find the element.  Place it into the correct design option.
NathalieKD
Yes, but there were too many. I ended up accepting primary. Isn't there any way to get alerted of this in advance? I.e revit not letting you create something by mistake in a option instead of the main model.
It would be difficult for Revit to determine if you're doing it by mistake or on purpose.
L_JOSE_2011
esto se solucionó en revit 2021 pero en revit 2024 y 2025 veo que sigue ese error
