Revit opens projects in sperate windows
amirhossein.jafarii
Message 1 of 8
amirhossein.jafarii
All,
It has been few days that when I want to open another project in Revit it will open in "separate windows" meaning that I can't copy-paste items..or even import families in projects...
I appreciate your help.
Thank you,
Amir
Replies (7)
Message 2 of 8
Open them using File menu within Revit.
Message 3 of 8
Same Revit Version?
Message 4 of 8
RDAOU
@amirhossein.jafarii
You need to re-associate the file extension .rvt with the right Revit.exe. Usually Done via the registry; however, if you are not familiar with that, you can try if the following works
(Even if they are already associated with Revit, re-associate them)
  1. From windows file explorer, select and right clock a .rvt file
  2. Select Open With
    • Make sure to check Always use this APp to open .rvt
    • Select More Apps
    • Scroll down to "look for another apps on this PC"
    • Navigate to C:\Program Files\Autodesk\Revit 2022    (or Replace 2022 with the latest version you are using)
    • Select the Revit.exe found in that folder
RDAOU_0-1636978852019.png          RDAOU_1-1636978914069.png         RDAOU_2-1636979051372.png
If the above doesn't work, you will need to
  1. re-associate the Shell/Open/Command with the right application -
    • Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Revit.Project\shell\open\command
  2. and set the DDEexec to [open("%1")]
    • Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Revit.Project\shell\open\ddeexec
If you are not familiar with editing the registry, it would be best if you ask an IT specialist to assist you with that
Message 5 of 8
benB6WS9
Thank you! The "More apps" part is the thing that fixed it for me.
Message 6 of 8
RSomppi
You should always open projects from within Revit. This is especially important when you have more than one version installed.
Message 7 of 8
ryley.g.h
You cannot copy/paste or transfer project standards from two different instances of Revit. You need to open BOTH files within ONE Revit window, then you can do the copy/paste or transfer project standards.
Message 8 of 8
angels2504
This helped me too much thank you!
