Revit on Parallels 12 for Mac
Message 1 of 16
I'm using Macbook pro, and downloaded Parallels 12 to install windows 10 on it for the software.
I put the V below, and when I'm trying to use it, it does nothing and get stuck, and even can't be closed.
Is it because of the Parallels? Installation problems?
would like to get your help.
Thanks!
Replies (15)
Message 2 of 16
JvanReij
Hello Ilan,
It is a pretty common issue, sadly enough there are a couple of things that can cause this.
The two most common causes are that the graphics card driver may be corrupt or the Microsoft DirectX® End-User Runtime may be corrupt.
  1. Download and install a new copy of the graphics card driver from the Certified hardware page.
  2. Download and install a new copy of the Microsoft DirectX® End-User Runtime from this page.
There are two more possible solutions, I can type these out but there are two links where you can find step by step instruction:
Link 1
Link 2
I'm convinced this solves your issue, if not feel free to contact me.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Message 3 of 16
Thanks for responding.
I downloaded the DirectX and installed it, but the problem wasn’t solved.
Thr first link to the certified hardware contains only AMD and Nvidia, while Im using Intel Iris 6100 – so what can I do now?
Also, I tried Link 2, but when I checked the box mentioned it the Opthions bar in Revit, it showed the same alert that I wrote about.
Thanks for your help!
Message 4 of 16
JvanReij
Hello Ilan,
Are you still experiencing the problem?
Friday I have some spare time, I'll think about your issue and post another possible solution. You'll hear from me soon.
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Message 5 of 16
Hi
The problem is still not solved.
I'll be waiting.
Thank you.
Message 6 of 16
JvanReij
Hello Ilan,
I looked a bit deeper at your problem, at this moment I only found that there is a newer version of Revit released (Revit 2017.1) that has a lot issues solved, like with 3K screens. If you try to instal this one and still have the same problem we can consider that we look at the problem together with TeamViewer.
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Message 7 of 16
I tried it and it didn't worked, so I decided to install Windows by boot.
After that I tried to install Revit, and it says 75GB are required - place I dont have because it was devided with the Mac. 75gb are realy required?
I tried to choose external hard drive to install, but it didnt let me.
Get Outlook for iOS
Message 8 of 16
JvanReij
Hello Ilan,
My apologies for the late reaction.
For Revit you only need (a minimum of) 5gb, the message you receive is a known issue. In the following link, you can read the solution.
Link
I hope this helps you further.
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Message 9 of 16
Hi, the link does not work. I'm having the same issue. Thanks.
Message 10 of 16
Viveka_CD
Hi @Anonymous
Can you specify which link isn't working?
Also, let us know what you are looking for?
Please post a screenshot so that we can troubleshoot further.
Message 11 of 16
pixelwash
Dear VivekaCD,
If you followed this thread, you would see that the "link" in the accredited answer from the Autodesk support guy no longer works - that's the question you responded to.
And yes, I'm having this problem also, as well as the original question posed in this thread, and it is NOT solved in this thread, because the link does not work. You asked for a screenshot, and I've attached one FYI.
But the real problem is getting Revit to work with graphics acceleration in Parallels on a Mac i.e. in emulation. 3Dstudio max 2017 DOES work with hardware acceleration in Parallels 12.
Message 12 of 16
Viveka_CD
Hi @pixelwash
Thanks for getting back! Smiley Happy
@JvanReij can you fix the broken link? please see the pic attached by @pixelwash
Please see more information on System requirements for Autodesk Revit 2018 products
As for 3dsmax see the article HERE
Message 13 of 16
RE: Link being obvious if she'd followed the thread:  I followed the thread and notice Four "Links" listed in his 11-03-2016 11:39 PM post, plus the one in the later post.
@pixelwashwrote:
Dear VivekaCD,
Perhaps I'm also not following as well as you are
Message 14 of 16
Viveka_CD
Hi @Anonymous
I'm waiting for @JvanReij to get back on the 'link' he shared which is apparently not working.
Also, I did not see a screenshot can you please resend?
Message 15 of 16
JvanReij
Hello @Viveka_CD,
That's a good question, the link was from one of our partners that posted it on a knowledge page.
To bad this page is not working anymore, I'll try and contact our partner to see if he still has the information offline for us. I don't know anymore myself what the information in this link was about that solved the issue (with time passed).
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Message 16 of 16
Viveka_CD
Hi @JvanReij
Thanks for getting back to us! I appreciate it.
We will look forward to the information.No worries Smiley Happy
