Revit not working after installing
I just installed revit 2016 for students, the installation went well, but when I open a new template, I cannot see the taskbar unless I click on something. If I try to do something (open a new file, create a property line) the program freezed and I have to close it with the task administrator. Also the taskbar below keeps flashing.
My laptop is dell 7710 (64 bits), it came with windows 10 pro.
Trying to fix it I installed microsoft .net framework 4.6.1 and both autodesk revit 2016 service pack, but with no luck.
I'd appreciate any kind of help.
ennujozlagam
hi, try to change your diplay setting to 125% or 150% if this one works for you. try to install latest updates and service pack from autodesk and updates your graphics card to the latest.. thanks
Thanks! It worked!
