REVIT not synchronizing?
WILL137
WILL137
Is anyone else having trouble synchronizing in Revit?
Disable the antivirus or firewall temporarily then test to see if you can sync to central.
Disable the Revit add-ins then test to see if you can sync to central .
ennujozlagam
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-20...
WILL137
Thank you for the suggestion the problem resolved itself.
WILL137
Thank you for the suggestion, thankfully the problem resolved itself.
