revit not responding when converting to dwg!!
I'm facing a problem in a revit file. I uploaded furniture blocks from a website called revit city, these blocks seemed to be infected with virus as when i load them into my project a message appeared from antivirus that a threat has been detected. When i tried to export my file from revit to autocad it uploads till 50% then the revit became not responding. I was wondering if the file is infected would you please try to recover the file without deleting it.
found attached screenshot of my memory when revit is not responding and am uploading the revit file and will post download link soon hope i could found help here as it is very urgent thanks .
here is the .rvt file 2015 i hope that someone download it and try to convert it by himself to .dwg
https://www.dropbox.com/s/ixkdo3ju0ft3opm/Midterm%20Submission.rvt?dl=0    (75mb)
open revit model
open default 3d view
right click on Typical Floor view and choose delete
go to View tab of ribbon
go to create panel
click Plan View
choose Floor Plan
select the level to associate the new plan view to
new plan view is made automatically
in your situation, your level Typical Floor Level is associated to your Site view.  Rename the Site view as Typical Floor OR right-click and duplicate it.  Rename the Site view as Typical Floor and the copy as Site view.
adjust the new Typical Floor view as desired.
solved by dzanta
