Revit not printing Wysiwig. Text size distorted. Both in printed and pdf format.
Message 1 of 11
pdf example included.
Replies (10)
Message 2 of 11
ennujozlagam
It's looking fine to me. Can you please highlight which one. Thanks
or try to print to another printer driver like BULLZIP .etc. and see if helps.
Message 3 of 11
Please look at the second page of the pdf document. The first page is a screenshot and the second the pdf print
Message 4 of 11
ennujozlagam
Ok, now I see it. Have you try another printer driver?, like BULLZIP, CUTEPDF..etc,  it's free you can download from the internet. Thanks
or try to change FONT and see if helps.
Message 5 of 11
I get the same identical result in Adobe, Bullzip and Soda pdf.
Does not seem to be the printer driver setup.
Message 6 of 11
ennujozlagam
is there anyway you can share the here so we can check. thanks
Message 7 of 11
RobDraw
You subject makes it sound like neither is correct. If you really mean only the PDFs are incorrect, have you tried capturing the fonts for PDFs?
Rob
Message 8 of 11
What is your Windows Display Scaling?  Try 100%.
What is the font used in Revit?
Message 9 of 11
No success so far.
I updated Windows 10 and drivers.
Tested various fonts.
The font is correct but display size is wrong in printer and pdf format.
Image show screen and pdf display.
Screen layout is correct but print layout distorted.
Message 10 of 11
Did you check the Windows Display Scaling?
By the way, it is WYSIWYG.
Message 11 of 11
Problem solved
Thank you ToanDN
I use a 4K screen on 150% scaling.
When set to 100% scaling for the display all is fine.
Thank you.
It seems that Windows 10 and Hi Res monitors does not integrate that well.
