- Mute
- Permalink
- Report
In the past when I have pdf'd a floor plan it will print all lines as vectors (so when you open it in adobe illustrator for example you can select each line). Now all of a sudden it is printing things in a box and I can not select individual lines. I do not think this is an adobe issue (I opened an old plan that I know works and it was fine). I tried saving the model on a local drive (not connected to my work VPN), having a coworker pdf it, updating adobe software, restarting revit, restarting my computer, I clicked the remove lines using vector processing, remove lines using raster processing, printing just the view, printing on a sheet. Nothing seemed to work.
