REVIT MULTIPLE IF CONDITIONS WITH 4 PARAMETERS
Hi Everyone,
I wanted to create a formula with 4 parameters and it reflects back in Text Parameter.
For Example,
If A is Checked it should display "A";
If B is Checked it should display "B";
If both A and B are Checked it should display "Select any One"
If both A and B are unChecked it should display "No Text".
For two parameters I wrote the formula but I wanted this to be achieved with A, B, C, D.
Any help or suggestions will be appreciated.
Accepted solutions (3)
David_W_Koch
This should work for you:
if(or(and(A, B), and(A, C), and(A, D), and(B, C), and(B, D), and(C, D)), "SELECT ANY ONE", if(A, "A", if(B, "B", if(C, "C", if(D, "D", "NO TEXT")))))
The first if conditional tests all possible combinations of two of the four parameters to see if both are true, and combines those in a "or".  This will evaluate to True if any two or more of the four parameters are checked, and it returns "SELECT ANY ONE".
The only possibilities left are only one of the parameters is checked, or none are.  The else of the first conditional test is an if statement, testing to see if A is checked, if so, it returns "A", if not, another if tests if B is checked, if so, it returns "B", and so on for both C and D.  If the logical flow gets to the final else, then none are checked, so "NO TEXT" is returned.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
FAIR59
Formula's easy to expand for multiple conditions:
parameter [ Checked_Count ] is an integer parameter
Awesome, Understood the logic behind the formula and I got the desired output. Thank you!
Thank you so much! I wonder this can be achieved through this method as well! Definitely a helpful method!
kovyljan
lookup table. More limitless possibilities
С уважением, Ковылин Сергей Сергеевич
Инженер-проектировщик; BIM-менеджер
моб.: +7 (927) 201 57 72
Skype: kovyljan
E-mail: kovyljan@mail.ru
VK | Telegram
Expert Elite Member
ОТВЕЧАЕМ НА ВАШИ ВОПРОСЫ НА ФОРУМЕ BIM2B
