Revit Model to .stl Glitch
Message 1 of 14
Hi!,
Im facing a glitch in my exporter in revit to .stl model. In my revit file its all solid and no holes, but when I already convert to .stl using Revit Plugins already got the voids. I have attached some images i capture from my model. Thank you ! I hope you can help me about this matter. Smiley Sad
SarahCat Happy
Replies (13)
Message 2 of 14
BIMAbhi
You can try by below process
Export the Revit model into DWG > Then export the dwg to stl
Thanks & Regards
BIMAbhi
Message 3 of 14
I did try but it isnt exporting to .stl... I use model in-place casework to model my object.
Message 4 of 14
BIMAbhi
Are you using STL Exporter add-ins?
Thanks & Regards
BIMAbhi
Message 5 of 14
Yes Im using stl converter plug in of revit.
Message 6 of 14
Copy all the model and paste it into a fresh Revit project and then try to export the stl.
Message 7 of 14
Ok I will try . Thank you.
Message 8 of 14
Same problem :Cat Sad
I try to convert to cad but it says its not solid.. autocad isnt my forte coz I only use revit.. when I try to export it as .stl in cad it doesnt appear to the location where it supposed to appear. I did try to highlight everything before exporting it but still the same its not appearing. Cat Sad
Thank you!
Message 9 of 14
BIMAbhi
Can you share the Revit file.
Thanks & Regards
BIMAbhi
Message 10 of 14
ok 🙂 thanks!
Message 11 of 14
BIMAbhi
Attached the stl and one sanp file for your easy reference.
Thanks & Regards
BIMAbhi
Message 12 of 14
thanks alot! ill try it Cat Happy
Message 13 of 14
Hi again!,
I did try it its ok in the software but in the print preview got gaps, same problem Cat Sad
thank u so much!
Message 14 of 14
nithinchandra26
Observer
Observer
i need stl to revit plugin
