I've been trying to export a section of a building for printing, but when I load it into Cura slicer, the shaft area of the building appears with this weird geometry. I deleted the shaft, and opened a gap in the floors instead, but it didn't solve the issue. Do you know what I can do? I have to present this for class soon and I'm running out of time to print. Thanks!
Solved by L.Maas. Go to Solution.
Maybe you can do an in between step. For example export the Revit model to FBX and then clean it up in other software like 3dsmax?
Louis
Please mention Revit version, especially when uploading Revit files.
Did that but with Fusion, exporting to obj and then opening in cura, worked! thank you!
