Revit Model Checker
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The Revit Model Checker add-in from www.biminteroperabilitytools.com is way easier to use than the Autodesk extensions version.
But I’m still having enormous problems getting Model checker to work.
Simple things like checking if any Filled Regions are in a project are near impossible because Model Checker uses internal Revit parameters.
I’ve tried using the Revit Lookup add-in to interrogate objects but it just impossible to know what to use.
To be honest if you need to know the API in such detail you might as well write your own code to do model checking.
Does anyone know of any sources of information where simple tasks like what parameters to use to identify elements can be found? Or a forum where questions can be asked?
Model checking within Revit is a fantastic time saver, but the tools Autodesk provide are hopeless.
