Revit Measure Tool Options
Message 1 of 16
Is there a way to adjust the accuracy of the measure tool in Revit.
For example set it to round to the 1/8th rather than taking it all the way out to the 256th of an inch?
I take lots of measurements on pointclouds and this would make life much easier.
Replies (15)
Message 2 of 16
Message 3 of 16
This changes how dimensioning works but does not effect the measure tool.
Message 4 of 16
Kimtaurus
To change the measure tool, go to Manage > Project Units. Change the accuracy of the Length Format.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Message 5 of 16
That is not working. No matter what I set length rounding to the measure tool is not effected.
Message 6 of 16
I'm curious as why you actually use the measuring tool instead of dimension tool?
Message 7 of 16
Because i am working with pointcloud data. I just need quick measurements from the pointcloud before I build an object. For example taking a quick wall thickness measurement before placing a wall. Or taking endless measurements from an object to build a family. I just need quick measurements not a screen full of dimensions.
Message 8 of 16
Write down a list or a chart for your own translation. For example:
<17 / 256 = round down
17-48 = 1/8
49-80 = 1/4
81-112 = 3/8
113-144 = 1/2
145-176 = 5/8
177-208 = 3/4
209-240 = 7/8
>240 = round up.
After a dozen times your brain may do the math pretty quickly.
Message 9 of 16
andrea.kikuchi
Autodesk Support
Autodesk Support
Currently there is no way to adjust the units of the measure tool. Please feel free to visit the new Revit Idea Station where users can vote on ideas which may be implemented by development in future versions.
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Message 10 of 16
ericbeckman5564
It is now 2023 and this still persists.  After 30 years of working in construction planning, I don't recall ever having to measure something to a 256th accuracy.  1/8th of an inch is generally an accepted tolerance.
Message 11 of 16
shinkleVS2TJ
I'm also looking for a way to do this.
Looks like Autodesk would address this and somehow give us an option.
Message 12 of 16
virginia.fry.design
It is a little odd to me that this function does not already exist.
Message 13 of 16
cvanriper
RIGHT?!  I HATE THAT I CANNOT CHANGE TO 1/8" TOO.
Message 14 of 16
joeleolson
Observer
Observer
I agree.
Message 15 of 16
Basam.Yousif
Posting to keep this discussion alive.
We still don't have an answer, do we?
Message 16 of 16
RSomppi
See message #9. That is the answer. Keep it alive in the Ideas forum.
