Revit LT
Revit LT
Revit LT
I will soon be purchasing Revit LT 2015 and will train on it over the winter.  I currently have been on Autocad and/or Autocad LT for the past 10 years or so, so I am a seasoned CAD user.  There are not too many (if any) Revit LT training tutorials out there because Revit LT is a relatively new product.  My question is this, if I train on a standard Revit tutorial are Revit and Revit LT similar enough that I will be able to learn Revit LT using a standard Revit tutorial?
Accepted solutions (3)
loboarch
You can probably use almost any Revit training materials for Revit LT.  The differrences are fairly subtle.  Most books/tutorials will work just fine for learning the basics of Revit as a software.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
I thought that might be the case.  Thank you
David_W_Koch
If you get into advanced topics, just keep in mind which features of Revit are not included with Revit LT, and, as Jeff mentioned, most Revit training materials will work with Revit LT.
http://www.autodesk.com/products/revit-lt/compare/compare-revit-products
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
