Revit LT + IFC + Rooms
zeichenbueroAUTCV
zeichenbueroAUTCV
Just a quick question,
Is it possible to create rooms from an IFC with REVIT LT?
This link needs e.g. REVIT and not REVIT LT:
https://graphisoft.com/downloads/interoperability
The architect uses ArchiCad
Thanks in advance
javierBFS8M
I think you can do with a dynamo script (perhaps some python coding is required). I have sucesfully transform ifc structural columns into native revit structural colums. You need a full Revit license in order to use dynamo.
machycekF254L
Revit LT does not support API, you will be unable to install "IFC exchange with Archicad" add-in.
Thanks in advance
Are you talking about the Add-In for Revit? If so, how did you determine it wasn't for LT?  Did you try and fail?
