How to view the deducted part of a component in Revit?
19 ANTWORTEN 19
Nachricht 1 von 20
23702173
1425 Aufrufe, 19 Antworten
After a Revit component is deducted by other components, how can you view the deducted part of the component and obtain the deducted project quantity?
19 ANTWORTEN 19
Nachricht 2 von 20
RobRocks
als Antwort auf: 23702173
Your wording is hard to understand. Can you explain it in more precise Revit terms?
Nachricht 3 von 20
alan.johnson7YLND
Can you explain in more detail please, with maybe an image of what you want.
Nachricht 4 von 20
Yah, I think I understand. You cut something with a void and you can't select/see the attached void. I hate that too. Use the Uncut Tool and select the Solid geometry that the Void geometry is cutting to detach the void (make it orange again).
Nachricht 5 von 20
BTW: Cut/Join Geometry REMOVES Volume, so I'm unclear what you want from the Void Cut. If you want to determine the Volume that is removed, then you need to compare Cut Condition with Uncut Condition, much the same way Revit computes Topo Cut/Fill from Graded Region Copies.  Uncut condition is in one Phase and cut condition is in another Phase.  They're 2 separate elements being compared.
Nachricht 6 von 20
23702173
als Antwort auf: barthbradley
For example, there is a wall here, which is sheared by the structural columns on both sides and by the doors and openings on the wall. How can I know the engineering volume of these sheared parts?
Nachricht 7 von 20
23702173
This is the test file.
Nachricht 8 von 20
WinZIP? That dinosaur is still kicking? I thought it was extinct.
Compress your RVT using Windows -- if you have to compress it at all.  Did you try attaching the RVT directly?
Nachricht 9 von 20
23702173
This is the test project file.
Nachricht 10 von 20
23702173
This is the attached project file for the test.
Nachricht 11 von 20
You know, without seeing your Model, I'm thinking that Parts and Parts Schedule might get you to where you want to go.  I'm talking about breaking the Walls up into Parts via Create Parts.  You follow my thinking?
Nachricht 12 von 20
23702173
Why can't Revit directly see the deducted part of a specified component and the amount of work done by the deducted part?
Nachricht 13 von 20
I opened up your RVT and am looking at it now, trying to make sense of it all. The fact that everything is in Chinese isn't helping.  What exactly are you trying to do? Schedule out how much Wall it cut by the Columns?  If so, what's the construction sequencing.  Wall already exist and Columns are new, that's why the Columns are "clipping" the Wall? If not, why doesn't the wall fit exactly the space in between the Columns?  I need way more info here.
Nachricht 14 von 20
23702173
Thank you very much for viewing my project files. My main purpose is to calculate the wall engineering volume. When the length of the wall is between the two axes, it exceeds the range of the structural columns at both ends. Part of the wall is inserted into the structural columns, so this part will be deducted by the structural columns at both ends.
Nachricht 15 von 20
23702173
In addition, there are doors and openings on this wall. Now I can only see the total amount of this wall after deducting the structural columns, doors and openings at both ends through the wall details, but I cannot get the individual quantities of each part of this wall that has been deducted, such as how much the door deducts from this wall, how much the opening deducts from this wall, and how much the structural columns at both ends deduct from this wall? These cannot be displayed or queried in Revit.
Nachricht 16 von 20
You need to learn about Project Phasing. That knowledge is critical here. There are plenty of tutorials and videos on-line that can assist you.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-2E104AB8-68B9-46F2-9BE2-B54E767429E5
Nachricht 17 von 20
23702173
Is there any correlation between the deducted part of the wall and the project quantity and stage?
Nachricht 18 von 20
Yes.
Nachricht 19 von 20
23702173
Those are just the deductions for the doors, windows and openings, and the deductions for the structural columns at both ends for the wall parts that extend into them. Is there any connection with the stage?
Nachricht 20 von 20
23702173
Collisions have been implemented in Revit software, and the connection relationship between components can be identified. Why can't the deduction of engineering quantities between components be achieved?
