Revit LT 2026 - Cropped View is Rotated
BillAllenSE
BillAllenSE
When I rotate a view from True North to Project North, the Crop View boundaries also rotate. I think this will make it difficult to place it on a sheet.
How can I get a rectangular (rather than diamond shaped) cropped view oriented to project north?
Mike.FORM
How do you have project north set up, is it orthogonal to your building?
If you need to change the angle of project north it is done in the manage tab under position.
If it is just the callout that is not orthogonal to your building then just edit the crop boundary of the callout in the view by turning crop boundary on and selecting it.
BillAllenSE
Thanks. Editing the crop boundary works.
