Rotate Family in Multiple Axes: Nesting Face Based
paul_anstey
paul_anstey
Hey everyone,
I’m trying to build a family that can rotate on multiple axes, but I’m running into an issue where the geometry’s orientation changes once I nest the family for the second rotation, so that it's facing a different direction.
I’m following the method shown in this great video: Revit MEP - Rotating family - Option 1
Here’s how my setup is structured (from the innermost nested family to the outer host):
  1. Geometry – Face-based family containing the actual model.
  2. Rotation in Ref. Level – Face-based family using Reference Lines to control rotation from the top-down view.
  3. Rotation in Left Elevation – Another face-based family using Reference Lines to control rotation from the side view.
The problem: when I nest the second rotation (the Left Elevation version) and host the geometry to the new Reference Lines, the original rotation gets lost. The geometry’s base orientation shifts, and I can’t get it to line up properly again.
Has anyone managed to get stable multi-axis rotation using nested Reference Line setups like this?
Thanks in advance!
paul_anstey
I figured it out, using a much simpler method: https://www.youtube.com/watch?v=ELzBAY6fbC0
I had to pre-rotate my original geometry before nesting, to get the correct orientation.  Then I could nest again using the same rotation method to rotate on Z axis.
