Revit LT 2022 Material image crash
jamesVNTAR
Observer Observer
jamesVNTAR
Observer
Observer
Every time I try to replace or place a image map into a new or existing material Revit just hangs with spinning wheel.
I have set the render quality to draft for the preview and downscaled the image map as much as possible.
Any help appreciated. Thanks.
Lance.Coffey
Autodesk Support
Autodesk Support
Thank you for the question @jamesVNTAR and welcome to the Autodesk forums!
First thing I would suggest (if not already done) would be to install the 2022.0.1 hotfix.
If you see the same behavior after updating Revit LT, could you reply with a journal file recording the crash?
Lance Coffey
Technical Support Specialist
