Revit LT 2020.2 Bug - 0-0 node appears on sheet
1 REPLY 1
410 Views, 1 Reply
This happened when I updated Revit about a month ago, and there has been another update since that never fixed the bug. It is extremely frustrating to work like this. When I have multiple views on a sheet, the center point (0-0) node appears for each view. And when I select each individual view, even though my crop region appears correctly, the area selected is a large rectangle that has that center point node in its view. This is how it appears on a sheet for me: This is not just a one off sheet or a corrupt file. This is every project and every sheet that I work on. Seeking autodesk assistance/ update immediately.
Curtis
Labels (2)
1 REPLY 1
mauricio_mssf
Hello @Anonymous
Within the visibility/graphic configuration on model Categories on your viewtemplate go to the site, and deselect the option of internal origin, both in plans, as in sections and views.
Or in viewtemplate or in each view.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
