REVIT LT 2017 Families Library
Message 1 of 8
I have installed Revit LT 2017 but none of the materials or families libraries have installed. I've looked on the community forum and tried the recommended solutions of uninstall/reinstall and manually downloading and saving the XML file. I get the required check-boxes when selecting what content to download and have tried both English & us metric, following which I am being told installation has completed successfully. However when I check within the C drive location, there is no sign of any family or materials libraries. I have now been at this a couple of days and have used up most of my data allowance in download/uninstall and download again.
Any assistance gratefully received.
James
Replies (7)
Message 2 of 8
RDAOU
Hi @Anonymous
  1. how or where from are u installing? Is it webinstall or downloading and installing locally?
  2. did u check under c:\programdata\Autodesk\RVT (version)
if u r going for webinstall u might/could experience all sorts of odd behavior all depending on how your IT setup is configured, Internet connection, firewall, AV, User Access...etc, and the list is long. I usually download the installation files from Autodesk Virtual Agent, extract and run the installation locally...that always worked perfectly ok
Message 3 of 8
Thanks for that
You are correct, I used Webinstall
Have now located the template files by viewing hidden files and have updated the links to them from Revit, however I still don't think it's all working quite right so would like to try download then install.
How do I access virtual Agent whilst logged on to my account (or log onto my account whilst in virtual agent) - when I use the links you provided I can find the downloads but can't access them.
James
Message 4 of 8
RDAOU
You don't need to be logged in...there is a link in my signature below. Download >> extract >> installation runs automatically (do not install anything thou...u just need the libraries and templates; unless your current installation is broken and u want to reinstall everything in such case you will need to clean uninstall first the reinstall using the files you downloaded from virtual agent - then use your current credentials to activate)
Message 5 of 8
Sorry, the link takes me there but when I click on the file to download I get an "HTTP 403 Forbidden"  page saying the website declined to show this webpage.
Message 6 of 8
RDAOU
Thanks for the feedback...i will report the broken link for them to fix it
Message 7 of 8
RDAOU
@Anonymous
As confirmed by support team the links will be back up and running very soon. In the meantime you can use the following links to download the 3 parts of REVIT LT 2017 (download and keep for future troubleshooting when or if needed... Will let u know when Virtual Agent links are back online
REVIT LT 2017 Part 1 - Download
REVIT LT 2017 Part 2 - Download
REVIT LT 2017 Part 3 - Download
Ps. Thanks and credits go to @Darin.Green who provided the above links
cheers : o) and hope the above help
EDIT: seems the links on Virtual Agent has been already restored
Message 8 of 8
ramona.randolph
I just bought Revit LT yesterday and I am having some big issues.
1. There are no templates
2. There is no viewcube in the floor plan, and no elevation markers, which are standard when you open any Revit product
3. There are no families. When I to to put an item in, it asks me if I want to load one. When I say yes, it takes me to a lot of folders with coded names that I do not recognize.
I keep getting this opening message:
"The path you have specified for the default family template files is invalid."
I set up a phone appointment for this morning, but no one called. After you pay them, there is no more "chatting", no more specialist to call and sell you. You are on your own with forums. I'm no IT guy. I just use Revit for my interior dwgs. The trials worked fine. This is completely ridiculous.
