Revit looks Pixaleted
Hello, I currently downloaded revit in my computer, and when I open the program it looks "Pixaleted" or over zoomed, the tabs don't look sharp neither the commands.
If anybody can help me how to set it up so it wont look like this.
Here is a picture attached
Maybe the program has to be like this, or Im just exaggerating..
Thank You
What part? It looks perfectly normal to me.
JasonKunkel
It looks like you might have a SUPER HIGH resolution with scaling turned onto something other than 100% in Windows.  Revit is sadly not a fan of this.
To test, you will need to go to your Display Settings, change your resolution to something manageable, and then slide the "Change the size of text, apps, and other items" to 100% - assuming Win 10 here.  Might need a reboot.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
LinkedIn
loboarch
This is what it looks like to me as well.
Make sure you have the latest version of Revit installed. I know 2017 had some fixes released for UI scaling issues. Try a lower scaling value and restart your computer with the new scale value. This can make these display issues go away.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
