Revit local file discrepency
Hi all,
Wonder if anyone could help me on this one; when creating local files in our office, I have noticed for a particular project, a level is missing on local machine A and the rest of machines display the correct information. Would this be a result of a corrupted file or issue with the local machine?
Below is an screenshot of the missing L01 (I have checked the hidden views and maximized the level extent with no luck)
Is there a solution for it?
Kevin
ennujozlagam
try to install latest updates from autodesk and uncheck use hardware acceleration form options, updates your graphics card driver to the latest and see if helps. thanks
It could be that the level is on a workset that is switched off on the local machine.
Usually if one pc shows elements and on another these elements are missing it's a worksets issue.
Make sure all the worksets are on.
Create a new local from the central as a "turn it off/on again" test.
