Revit Links Grayed Out only some View Templates
meilechTPVL4
meilechTPVL4
Hello Anyone
I'm working in a Project with Some linked Revit Models
when I create some views the Links are fine, In others the ling displays in halftone. I narrowed it down, and this only happens if I use particular View Templates. However I cant figure out which VG Override is doing this.
"Revit Links Dispaly As Halftone" is not Checked
Discipline set to structural does not affect this setting , I tested this.
ther is no halftone on any VG Overide
Workset Visibility is default and the Active view is also gray
all VG settings are by host view
Hard to diagnosis/troubleshoot without seeing the RVT.  You can post it here if you like.
Also, this might help you figure it out:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-D...
Are the links set to Underlay in the view template?
meilechTPVL4
no the links are not set to underlay
I removed the view template and manually copied over every VG Override and setting I could find and created a new template.
I can bounce back and forth between templates some are grayed out and some are not I just dont know which setting is controling it in this case
